whistling from inside the block?
so ive been having a very strong high pitched whistle from my car after it gets warmed up. when its cold it doesnt seem to happen. when this whistling starts its not bad then it gets higher and louder. as this is happening the idle goes from its normal 800 rpms to up and down and up and down. it wants to die then it revs up and back and forth. so i originally thought it was the IAC motor on the throttle body but after tightening the screws, getting a new gaasket for it and listening to the sound i dont think its that. i think its comin from the block somewhere but i cant pin point it with spraying carb cleaner around where i think it is. the check engine light isnt coming on but its not driving like it should and the weird idle and whistling has been driving me nuts. if anyone has any suggestions please, ill take any help i can get.
thanks in advance..
chris
thanks in advance..
chris
might have a head gasket going maybe a intake gasket cause to throw the rpms out like that its getting area from somewhere it shouldnt be. also if it only happens when motors is warm then tht means it something happening durring expansion. hope this helps
My Car also has a whistle and it's an exhaust leak coming from the headers. Havent had the time to fix it! It's fairly noticeable when your outside the car but not in the cabin. Also maybe check all your vacuum lines,my car had serious idle issues that have finaly been resolved.
yup that prob hit it on the spot, because i have that same whistle and i tried to figure it out last night. sprayed all vac lines with carb cleaner and nothing. but i know for sure i have a header leak. im sure hes prob right.
can u spray the header gasket area with carb cleaner to check?
I have some bbk's and they don't use sockets. I tighten them with an allen wrench tip. Check to see if yours are the same.
