bogs down when floored...
my car started doing this and I thought it was all of the above. But The timing being off plus a faulty coil actually made my car behave almost exactly how you describe ( 0-60 MPH in like 12 seconds). I adjusted the timing and threw a new coil in. it has all power and hasnt skipped a beat since then.
updated
ok heres an update...i put in new plugs and plug wires, checked fuel filter its good, checked coil its ok, adjusted idle, adjusted timing, swapped egr, cleaned iac...it runs a lot better now. almost full power as it did before, but when its floored it doesnt have the same sotp feel. theres still a slight hesitation and feels like its lacking a lil bit. any ideas on what i should check?
did you get the right tube for your injectors? I know this can cause some odd problems, here is a site that might help out, the 5.0 i worked on had the C&L 80mm unit with a tube setup for the 73mm and until we put in the right tube it cause all sorts of problems when he went to larger injectors.
http://www.cnlperformance.com/calibration.html
updated
hey guys its been a while since ive been able to work on this car. but i checked it out tonight. it still runs fine, but only like up to 3500 rpm. if its like 3/4 throttle it seems fine. but once you floor it and it gets close to 3500 rpm it feels like the car isnt making any power. my throttle cable is f'ed up. the part that connects into the lil clip underneath the t/b wouldnt stay in there. so i had to pull on it some. seems to have loosened it up a bit. although once the gas pedal is floored the t/b does open fully. i just cant fig out what to check next. it doesnt have full power once floored it just lags. ive changed egr, new plugs, wires, fuel filter is clean...i just dont get it. there is still a light whistle and rpm change at idle, but im thinking its my header leak.
any other suggestions on what to troubleshoot?
you positive your coil is good? what color spark are you getting from ur plugs? it should be like a light blueish white if its orange then ur coil isnt producing enough and should be changed. this happened to me and i couldnt figure it out. swapped the coil out and rand mint
My car is modified cam rockers heads, intake exhaust but I have stock fuel system. Mine was doing that, when floored it would studder bad half the time and sound like it was backfiring int the intake at lower rpms. I do not have a timing pointer so after tiringly messing with timing and fuel pressure I finally got it right 38psi and only premium fuel, maybe u got some pad fuel also
