86gt rough idle and missfire
Old 10-18-2009, 03:44 AM
gthokiwi
gthokiwi's Avatar
Default 86gt rough idle and missfire
ive got an 86gt with edelbrock heads and 2.02 valves. its had the cats removed but still has the O2 sensors in place. the EGR valve is gone and the hole has been sealed.
i;ve had a couple of problems with it though:
first problem is the idle, it surges a bit between about 800-1500rpm. sometimes it will keep doing this till it stalls and sometimes it won't do it at all. i'm planning to pull the manifold apart and replacing the gaskets. any ideas what else i can do to help it?
second problem is that driving at low rpm say below about 2500rpm it sometimes missfires slightly but not bad. and often feels like it gets restricted, like the power is held back. then you put your foot down a little bit more and after a couple of seconds it feels like someone flicks a switch and all the power comes back. could this be the plugs and leads? how about dirty injectors?
cheers
gthokiwi is offline
Old 10-18-2009, 03:56 AM
86 5.0L
86 5.0L's Avatar
haha mines the same way, congrats you own a 5.0
check vacuum lines, pull codes and post back the details
86 5.0L is offline
Old 10-18-2009, 04:07 AM
gthokiwi
gthokiwi's Avatar
by pull codes you mean computer diagnostic?? can you do that on an 86? i just assumed it was one of the things that was introduced on the 88 model.
where is the diagnostic plug?
gthokiwi is offline
Old 10-18-2009, 04:34 AM
gthokiwi
gthokiwi's Avatar
ok so thats my engine bay, its a work in progress, bit of a mess, don't judge me!
i don't have a MAF sensor there i don't think? in this case what measures the air flow into the engine?
gthokiwi is offline
Old 10-18-2009, 06:38 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Well, for the idle issue, it could be the IAC, try removing it and cleaning it or just a simple vacuum leak. For the flat spot, it could be the tps. There may be a dead spot in it. You'll need some type of graphing meter to be able to watch it's range of movement.
PRO50SC is offline
Old 10-18-2009, 06:49 AM
gthokiwi
gthokiwi's Avatar
how does the TPS sensor work? is it just like a variable resistor type thingy?
before i cleaned the manifold for pictures, dust was sitting noticeably more around the joint i have highlighted. would this suggest a vacuum leak at that point?
gthokiwi is offline
Old 10-18-2009, 12:44 PM
86 5.0L
86 5.0L's Avatar
not really, take a can of carb cleaner, turn on the car and spray around on lines and any areas you think there are leaks, if the rpms shoot up then you found a leak, also heres how you pull codes from the ecu
http://sbftech.com/index.php/topic,2471.0.html
86 5.0L is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: 86gt rough idle and missfire
