347 Build help.
347 Build help.
I am planning to build a 347 this winter for my 92'GT. I already got a set of AFR outlaw 185 heads to start.. Who sells the best rotating assembily? Also if I wanted to get a donor motor from the Junk Yard, what should I pull it from. I was just there and there were alot of 5.0L in pick up trucks, cougars, Mercury's. Which one is better to get or does it even matter? Any info will help. I have a local machine shop to do the machine work, and install the bottom end. The rest I am gonna do. Thanks
Those AFR 185 heads are going to be a bit on the smallish side,IMHO.
I also don't really think it matters if the block comes from a truck, Lincoln or what ever. Just make sure it's a factory roller block. Coast High Performance sells some nice stroker kits, good service and all. DO NOT pay them to 'balance' the rotating assembly, they really can't do it right without having the balancer and flywheel/flexplate you are going to use.
Have the balance done locally..........
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
