Rear Disc Brake conversion problems HELP!!!
Old 10-24-2009, 09:34 AM
bsmi16490
bsmi16490's Avatar
Default Rear Disc Brake conversion problems HELP!!!
I have a couple of questions I hope someone can answer.
I have an 8.8 factory 3.27 rear.
It has Ford Motorsport Adapters on the ends of the tubes for disc brakes
This rear was 4 lug. I had another rear thats was 5 lug converted, used those axle shafts in the disc rear and I cannot find a rotor that will fit.
I looked at all the rotors listed below
Lincoln Mark vii
mustang 94-95
Thunderbird turbo coupe
explorer
Mustang 94-95 was the closest but still too large in diameter. I work at a machine shop and can turn the outer diameter down and will work perfect but hate to go to all that trouble if there is a rotor that will fit. The calipers I have are explorer I believe, built in emergency brake.
Guys, let me know what yall think.
thanks
bsmi16490 is offline
Old 10-24-2009, 10:44 AM
88GTBLACK
88GTBLACK's Avatar
You say the diameter of the rotor is too large? What are you saying your not clearing your wheels? Describe to us your fitment issue a little bit better and we'll be able to help you a little better.
88GTBLACK is offline
Old 10-24-2009, 02:43 PM
bsmi16490
bsmi16490's Avatar
the rotors are rubbing the calipers, they are rubbing the frame work of the calipers between the pads. I thought about grinding the calipers fo clearance but decided that I would rather modify the rotors than the calipers. With the hydraulic pressure I did not want to run the risk of weakening the frame work of the caliper.
JonnyBlazeGT
11-03-2015 01:10 AM
Tyoung68
08-25-2015 04:31 AM
dba Brakes
08-23-2015 06:08 PM
Fast-Hands
08-19-2015 06:54 AM
cvarner131
08-17-2015 07:38 AM
Quick Reply: Rear Disc Brake conversion problems HELP!!!
