no balls when hot
Old 11-08-2009, 11:50 AM
wadesquad
wadesquad's Avatar
Default no ***** when hot
after the car warms up it has a significant loss of power... i dont have any dyno #s to compare to but i can tell a big difference.. my air charge temp sensor is showing proper temps and the coolant temp sensor is running form 195-208 as the fan cycles.. my fuel pressure is right @ 39 psi.... 14* timing... i watched my timing on a scanner and it advanced form 20*-40*.. any ideas?
wadesquad is offline
Old 11-08-2009, 12:39 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Does it feel like its got a miss or just lacking power. Is there anyway you can check f/p when this is happening. Maybe a clogged f/f or pump on the way out after getting warm.
PRO50SC is offline
Old 11-08-2009, 12:53 PM
wadesquad
wadesquad's Avatar
i havent checked the fuel pressure as im driving.. ill check that a post my #s..
after it warms up it doesnt miss but it does die sometimes unless i feather the gas
Old 11-09-2009, 04:11 AM
holyshift
holyshift's Avatar
I believe Pro50 is on the right path,especially if you have to feather the pedal.
holyshift is offline
Old 11-09-2009, 09:55 AM
19905.0stang
19905.0stang's Avatar
you could try to put a lower thermostat in it like a 180 of 160 degree thermostat
19905.0stang is offline
Old 11-09-2009, 10:58 AM
nacanitihs
nacanitihs's Avatar
^^ that wont fix his problem
pro has the right idea on this one. go buy a new fuel filter they are cheap ($11 or so) and see if that fixes ur issue
nacanitihs is offline
Old 11-09-2009, 12:40 PM
mattdel
mattdel's Avatar
Although a new fuel filter is never a bad thing, you cannot tie it into a running hot problem. The filter sees no heat whatsoever, if its bad or clogged, it will shows signs no matter what.
The pump can overheat though, or have worse performance as it heats up. Checking the fuel pressure is a good idea, but my instinct tells me he's got an ignition problem, most likely the coil.
mattdel is offline
Old 11-09-2009, 07:00 PM
wadesquad
wadesquad's Avatar
well i was really hoping for a weak fuel pump... but no.. usual running psi is 37-40 and 45 @ wot then it dips to 34 after i take my foot out of the pedal
next:
i know a guy @ oreillys and he let me borrow a new coil... same no *****
i tested the igniton module and it passed all tests
is it possible that my problem crops up when the car goes into closed loop?
which sensors are not used when in open loop?
Old 11-09-2009, 07:02 PM
wadesquad
wadesquad's Avatar
i also hit the button on the guage hose to test fuel volume and i had a steady constant stream...
next:
Old 11-10-2009, 01:34 AM
mattdel
mattdel's Avatar
Anything closed loop related would be making very minimal adjustments to your fuel and timing curves, not enough of a difference to cause "no *****". You need to be looking in the direction of hardware failure caused by heat.
Since you tested the TFI(I assume while HOT), the next step is the PIP module inside the distributor, which directly controls injector pulse width & timing, through the TFI.
mattdel is offline
Quick Reply: no balls when hot
