Fuel Line Size
Fuel Line Size
Im going through a H/C/I on my 87 lx. I am changing it over to carbeureted and plan on running a regulator with a bypass so I can keep the stock pump, (for now anyway). The lines all seem to be only 5/16", is that sufficient for decent power? At what point do I need to bump it to 3/8"?
Figured 3/8 is 20% larger than 5/16" so figured I could bump the fuel pressure from 6psi to 7.5 to balance it out? Regular will adjust up to 9psi.
Did all the fuel injected engines come with 5/16" line or just the lx?
your looking for volume not pressure, uping the pressure will cause drivibility issue and not solve a lack of volume at WOT
FYI you will start blowing seals in your regulator with your stock pump. You need to either swap to a mechanical pump (not hard at all) or run a electric pump made for carbed vehicles such as a Holley Blue. Either option is going to require you to remove the stock pump out and put a piece of hose in its place or swap over to 79-85 tank. Then get the right timing cover for a mechanical pump. The stock lines from the tank will still get you enough fuel. The feed for it is 5/16 and the return is 3/8. You can purchase adapters to attach to the stock line right by the sway bar to run a steel braided line to the carb if you want to.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
mustangsrforever!!!
08-06-2015 12:04 PM
