Car feels shaky after new bolt on
Old 12-02-2009, 05:29 PM
92 5.0stang
92 5.0stang's Avatar
Default Car feels shaky after new bolt on
I installed a 75mm throttle body and since then my car started shaking while i step on the gas but when i let off it doesnt shake. Now i happened to grab this throttle body off a car in the junk yard. It has the oil tube blocked off . Should i unblock it and connect the tube that goes from the valve cover to the throttle body?
92 5.0stang is offline
Old 12-02-2009, 06:11 PM
camaroeater
camaroeater's Avatar
I would hook the tube back up and perform a base idle reset.
camaroeater is offline
Old 12-07-2009, 06:37 PM
92 5.0stang
i hooked the tube back up and did a base idle reset and it still shakes. this is a troubling problem. anyone else . any ideas are welcome
Old 12-07-2009, 06:38 PM
92 5.0stang
i hooked the tube back up and did a base idle reset and it still shakes. also since i installed the TB my acceleration isnt as fast it feels sluggish along with shaking? i didnt think that was supposed to happen or is that normal. this is a troubling problem. anyone else . any ideas are welcome
Old 12-07-2009, 06:43 PM
B.Thorson
B.Thorson's Avatar
75mm wouldn't be too much air would it? is the motor all stock?
B.Thorson is offline
Old 12-07-2009, 07:24 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
First problem, junk yard. Did it have a tps sensor already on it? May it's no good.
Yeah, what's the need for a 75mm t/b and if you are still on a stock mani it's no doing a thing for you.
PRO50SC is offline
Old 12-07-2009, 07:27 PM
lxman1
lxman1's Avatar
65mm is more than enough for a stock set-up. Did you use your old TPS sensor? The one on the new tb may be bad.
lxman1 is offline
Old 12-07-2009, 07:29 PM
92 5.0stang
I dont have a stock manifold . shoula mentioned that . i have a bbk SSi. and i used my tps sensor. and it looked like it was brand new it was polished and everything didnt look that used either.
Old 12-07-2009, 07:30 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
OK so have you tried swapping back to see if the problem goes away.
PRO50SC is offline
Old 12-07-2009, 08:09 PM
92 5.0stang
yes just swapped and tested and yes it still shakes. not as much tho
Quick Reply: Car feels shaky after new bolt on
