Stupid Question?
Stupid Question?
I am installing a 306 dss with all the goodies in my 88 lx. My question is, if i get a 76mm mass air meter calibrated for 24lb injectors, do I need to buy a mass air sensor calibrated for the 24lb injectors too? Thanks in advance.
RE: Stupid Question?
the mass air meter is the same thing as the sensor. well actually the sensor is inside teh meter. so to answer the question no. youll be fine. just remember if youre not MAF youll have to convert from SD to use a MAF
UH man you lost me.are you talking about the C&L meter if you are no you use the stock electronics on top of the C&L meter and you will need the 24# tube that goes in the meter.
if you buy the C&L meter tell them you need it for 24s and youll get the correct tube to go with it. if you ever upgrade or down grade you just tell them and buy the proper tube. only real good thing about C&L is that its only a few dollar upgrade instead of getting ti recalibrated
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
