still wont crank!!!
still wont crank!!!
posted a couple weeks back about my car not wanting to crank and how the solenoid just makes horrible noises when i turn the key. hooked the starter straight to the battery via jumper cables and it wouldnt spin.
i finally pulled the starter out and found chunks of metal inside it when i took it apart so i got a new starter and put it in today. hooked it all up, turned the key and nothing. hooked the starter directly to the battery again via jumper cables and the motor turns over just fine now. so the starter is good but the solenoid just makes this loud, horrible clicking sound. its done this with 2 solenoids now and i dont know where to go from here,
im not sure which ground to worry about. the fact that the motor cranks when i hook the batter via jumper cables directly to the starter means the starter is grounded just fine. i tried attaching a wire to the block off of the body of the solenoid (to ground it better, as if being bolted and sitting on the fender wasnt enough) and that did nothing either.
Your old starter could have fried the new solenoid. Check the in and the out wire of the solenoid for any corrosion. That corrosion moves into the wire like a fungus so if you have a little at the end, you will have more inside. Since you just bought a new starter, stick with that one. But when that one dies, you might want to upgrade to a modern mini.
You can do a simle voltage drop test on the feed and ground side of the starter circuit. That will rule out bad connections and bad wiring. Its a simple set of test that alot of people over look.
And i apologise in advance if you allready have done the above
i havent upgraded my starter since ive never had any reason too. its always worked just fine and if its not broken, dont fix it........at least when you cant afford to.
any links to a write up on that tho id like to look it up. any pics as well? there is some sort of solenoid on the starter and 3 terminals. one terminal goes to the starter motor, one goes to the solenoid on the fender and the other is a trigger wire. i just jumped that trigger terminal by wiring it to the terminal that has the wire going to the solenoid? this is how my mini starter was hooked up (last one i had that blew). should i just run a wire right off the battery to the starter and then run the 3rd little terminal (the trigger) to the wire that activates the solenoid on the fender?
Hey,
These links should work for you -
Description of voltage drop testing - http://ramchargercentral.com/index.p...,122771.0.html
And a great video showing the tests in progress on a no start vehicle - http://www.youtube.com/watch?v=ry68G0C2Fyc
Hope these help
Hope these help
