EGR delete for fox headers on 95gt
Had some fox shorties lying around. Figured I'd clean them up and put them on my 95gt. Read they should fit fine, only problem is the EGR valve. What would I have to do to delete the egr and not throw codes?
I bought a module that plugs into the EGR plug. It worked to get my check engine light off. Can't find one to show you. Also there is a resistor arrangement that you can put on the wires that does the same thing.
The best way is to tune it out in ECM.
module? all you need to do is keep the egr plugged in, even if its not functional and it won't throw a code
better yet, do it the right way and reprogram the ecu to delete the egr altogether
I do ford EFI tuning in New Orleans, LA, if you want a chip to delete the egr the price is $100 i can also reduce your fan temperatures, increase timing, remove the tip in retard, change your shift points, and any other adjustment you may need for just a few bucks more.
shoot me a PM
also a pic of this 'module' would be nice, I hope you didn't spend too much on it.
shoot me a PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
