Removing Steering Wheel '88 GT
I have the the whole dash apart and thee steering wheel is very loose but I don't know what else I have to do to remove the wheel. It has the tilt and it doesn't have an airbag. I removed all the hook ups and it doesn't look like there are any other bolts that need removed. Is there something else that needs to be removed?
Take the horn button off, remove the bolt behind it, bet a puller and pull it off. Or you can prop your knee's behind it to put pressure on it, then take a socket extension and a hammer and hit the center of the steering column, it should pop off, thats the way I was taught to do it with honda's
don't bash me, I work on them for money
09-10-2015 08:39 PM
09-08-2015 11:50 AM
