Jack Stand placement
Old 12-16-2010, 11:05 AM
jbakerinc
jbakerinc's Avatar
Default Jack Stand placement
To put a fox body on jack stands where is the best place to put the stands.
jbakerinc is offline
Old 12-16-2010, 11:29 AM
ryan_89_mustang
ryan_89_mustang's Avatar
Front frame rails close to the front and either the rear axle tubes or the rear frame rails by the torque boxes is where i normally place my stands.
ryan_89_mustang is offline
Old 12-16-2010, 01:38 PM
tohoopty
tohoopty's Avatar
i also use the k member if i gotta pull a tranny out
tohoopty is offline
Old 12-16-2010, 02:19 PM
AdderMk2
Banned
AdderMk2's Avatar
where the k-member bolts to the frame rails, and under the axle
AdderMk2 is offline
Old 12-19-2010, 02:19 AM
Jfsram
Jfsram's Avatar
Try to avoid placing stands on the frame. It's not much of a frame, just sheet metal, like the body and it's dents pretty easily.
It's also a bad practice to use 4 stands under the frame since one is usually not loaded.
The job your are lifting it up for usually determines where you hold it up from.
Jfsram is offline
Old 01-27-2014, 04:46 PM
5overt
5overt's Avatar
so if I am pulling motor and tranny all four up in the air where do I put them in the front I have been using lower a's but I dont love it
5overt is offline
Old 01-27-2014, 07:14 PM
reldla1996
reldla1996's Avatar
I usually place them on the frame rails in the front, and split 50/50 between the frame rails and the axle tubes (depending on what I'm doing) in the rear. The lower control arms move, and should not be used.
reldla1996 is offline
Old 01-27-2014, 09:01 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Ford says: Jack, Floor
CAUTION:
The service jack provided with the vehicle is only intended to be used in an emergency for changing a deflated tire. Never use the service jack to hoist the vehicle for any other service. Refer to the Owner Guide when using the jack supplied with the vehicle.
WARNING:
TO AVOID INJURY FROM VEHICLES EQUIPPED WITH A TRACTION-LOK AXLE, NEVER RUN THE ENGINE WITH ONE WHEEL OFF THE GROUND, SUCH AS WHEN CHANGING A TIRE. THE WHEEL STILL ON THE GROUND COULD CAUSE THE VEHICLE TO MOVE.
When using a floor jack, the vehicle may be raised at several locations. The front of the vehicle may be lifted by positioning the jack under the center of the No. 2 cross member. The front, as well as either side of the rear end, may be lifted by positioning the floor jack under the rocker flange at the contact points used for the service jack supplied with the vehicle.
CAUTION:
Do not attempt to use jack pressure on either front or rear bumpers of any unitized vehicle.
Position jacks under the rear axle housing tubes between the suspension arm brackets and the differential housing. Do not place jacks under the suspension arm brackets.
ALMOST STOCK is offline
Old 01-28-2014, 05:35 PM
Krochus
Krochus's Avatar
I prefer to put mine so the control arm just outside the front bushing slots into the stand.
Krochus is offline
mtgldr
02-03-2024 09:00 PM
Brett Ludlow
09-23-2015 06:59 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
09-17-2015 07:57 PM
uedlose
09-10-2015 03:30 PM
Quick Reply: Jack Stand placement
