PLEASE TELL ME WHAT SIZE THESE ARE (Roller Rockers)
OK I got these roller rockers from a friend for free. He said they were sitting in his shop forever. He also said they came off a mustang. When he brought them over they were in a mustang valve cover so thats good. But i cant tell what size they are. Its stamped with 1L 98 then under that it says crane... thats all the markings on it. I went to the crane site and tried to search for for the part # to see what size they are but I cant find it anywhere. Someone please tell me what these are! 1.6? 1.7? will they fit on stock heads?!
RE: PLEASE TELL ME WHAT SIZE THESE ARE (Roller Rockers)
Call crane and ask, or check summitracing for that part number...anyways, 1.7s and 1.6s will work with stock heads, I have stock heads with a FRPP B cam, and 1.7s, too, no clearance issues.
stud mounts wont work on stock heads without head work/modifiing
stock rockers are 1.6 and 1.7s or 1.72s will work on stock heads but valve cover clearence may have an issue
So are you saying these r stud mount?
OK i just got off the phone with Crane. He said they are 1.6 3/8 stud. What whould I have to modify to make these work? Id really like to use these it would save me a couple hundred dollars. AND does anyone kno where to buy the adjutsters individually. when he gave me the rockers they were missing 2 adjusters. What bolts would I use to to hold them down.. the stock 1s or do i need to go out and buy a set of bolts?
It would probably be cheaper to get a set of pedestal mount RRs. I paid less than $200 for mine. You would have to have your heads off and get them machined most likely, not worth it.
Sounds like a pain. Im going to sell these on ebay and pick up a new pair. From what I see these retail for over 300 bucks. I can get probablly between 150-200 for them (I hope) ... just about the cost for a new set that bolt right on. Any suggestions for new 1s? Should I get 1.6 or 1.7? what brand? 5/16's ?
Yes I know stock are 1.6. If I got some 1.6 rollers that would just mean less friction and maybe free up some horsies. So if i get 1.7 ... will they fit under the stock vavle covers? And will I feel a difference with the e-303?
