No oil pressure at idle
Old 03-20-2011, 04:53 PM
SVTeeshirt
SVTeeshirt's Avatar
Default No oil pressure at idle
Car is a 91 GT, had the intake manifold swapped to a gt-40, came out of the shop, and had 0 oil pressure. got a new Oil pump and sending unit, a long with a hydraulic gauge. Shows no oil pressure at idle but will go up when throttle is engaged like normal.
It's my friends car, i suggested trying to bleed the oil pump.
suggestions?
SVTeeshirt is offline
Old 03-20-2011, 05:46 PM
droptop302
droptop302's Avatar
The engine is not knocking? Sounds like shop he brought it to beat the hell out of it...
droptop302 is offline
Old 03-20-2011, 09:09 PM
SVTeeshirt
SVTeeshirt's Avatar
engine sounds perfect... no knocking or rattling around in the heads.
Old 03-21-2011, 05:39 AM
4rdnut
4rdnut's Avatar
Drain the oil, sounds like gas was poured into the lifter valley when they had the intake off, thinning out the oil.
4rdnut is offline
Old 03-21-2011, 07:45 AM
droptop302
droptop302's Avatar
He put a new oil pump in so i am going to guess its got fresh oil....
Old 03-21-2011, 08:12 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
could have some galley plugs that have blown out = happens, had it happen to mine years ago, doubt a shop beat the @#@ out of it.
mjr46 is offline
Old 03-21-2011, 08:34 AM
droptop302
droptop302's Avatar
Originally Posted by mjr46
COULD HAVE SOME GALLEY PLUGS THAT HAVE BLOWN OUT = happens, had it happen to mine years ago, doubt a shop beat the @#@ out of it.
galley plugs?
Old 03-21-2011, 09:13 AM
stdyhand
stdyhand's Avatar
I've heard of the galley plugs popping out and causing no oil pressure. There in the lifter valley and behind the timing chain if I remember correct. Someone else may know more about this. IF they didn't touch the block I wouldn't suspect it's anything in the bearings.
Whatever the cause may be, I would have to question WHY it was like this after he got it back from the shop.
Maybe after they swapped the intake someone decided to "test" it and drove it kind of hard, causing a plug to pop out.
Chances it would have happened anyhow at some point but it shouldn't be because of them.
stdyhand is offline
Old 03-21-2011, 09:30 AM
SVTeeshirt
SVTeeshirt's Avatar
but would oil pressure be there under thorottle even w/o valley plugs?
Old 03-21-2011, 09:37 AM
stdyhand
stdyhand's Avatar
Don't hold me to this but I would suspect a minimal amount of pressure, but I would think you'd hear a rattling noise from your valve train due to the lack of oil reaching your heads.
You can always pull your intake off and check the galley plugs.
Your saying there is no knocking or rattling. That makes me wonder if the oil pressure reading is even right because if the pressure was 0 or low you should hear some knocking, rattling, etc.
stdyhand is offline
Quick Reply: No oil pressure at idle
