302 dies when idling - help
Old 08-11-2011, 10:39 AM
dynamicracing2
dynamicracing2's Avatar
Default 302 dies when idling - help
I have 2 1994 mustangs with upgraded cams and intakes - both of them die when put in gear - if I hit the gas pedal they will stay running and they both are really fast
both have wild cams
one is a 289 with a cobra intake with 70 mm throttle body with 254 @.050 cam and .706 lift. the injectors are 19 lb ford and the computer is stock
the other is a 302 with "F" 303 cam and GT40P heads with an explorer intake and 70MM tb and stock computer with 19 lb injectors
what do you think?
dynamicracing2 is offline
Old 08-11-2011, 12:34 PM
AdderMk2
Banned
AdderMk2's Avatar
the F cammed car needs a base idle reset done, along with cleaning the maf and verifying that the O2 sensors are working correctly. The 289 with the .706 lift... you need a tune.
AdderMk2 is offline
Old 08-12-2011, 08:13 PM
dynamicracing2
thanks I will try that
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: 302 dies when idling - help
