Bad Alternator?
Old 11-05-2011, 12:12 AM
MythEyeLess
MythEyeLess's Avatar
Originally Posted by mustangGT86_05
Not necessarily true, a battery can show 12 volts and have 0 amps and that could be the cause. Voltage is the flow of electrons, something like 6.6 billion through a given point, and amps are pressure. But I have watched low voltage batteries start cars
Does your battery light come on while driving? If not, does it light up the self test when turning the ignition on? If it does and stays off while driving chances are the alt is pumping juice. Now with that said, it is possible the voltage regulator which would be overcharging the battery causing premature failure.
My suggestion, starting and charging is such a gray area you can't ask a forum and get a direct solution. Do the smart thing and take the car in to be tested, its usually free to have done.
Whoops did not mean to type 16 volts. However apms is just over complicating it... he wants a simple answer, so i gave him the simplest answer @@
MythEyeLess is offline
Old 11-05-2011, 01:37 AM
mustangGT86_05
mustangGT86_05's Avatar
No, amps is NOT over complicating it, its what allows your electronics to work. Look at it like this, you have a given amount of amps, well they need to be ate up by a load(s) by the time they hit the battery. When they aren't, that is what causes fuses to blow or otherwise. Voltage is merely a measurement of flow, in otherwords how quickly it can deliver.
Think of electricity as a water system, surprisingly they are nearly identical. Say a sprinkler, you can't opperate one properly without pressure. You can have a flow of water through it, but without pressure all that water will do is flow out, not spray.
This is coming from a certified ford electrical tech, btw, so it may sound like im over complicating it. Thing is, as I mentioned this is a gray area, just because you can say oh yeah a battery is bad doesn't mean that's the real issue. You can't test a battery based on volts, its there ability to supply amps. An 8 volt battery can still be good, may just need charged to provide a proper supply.
Im rambling, but if you want to attempt diagnostics, you gotta know what you're talking about. No offense, but it sounds like you have a lot to learn. Trust me it takes a lot lol
mustangGT86_05 is offline
Old 11-05-2011, 12:14 PM
masamu6012
masamu6012's Avatar
It was the starter. Just swapped it out and it's starting up fine now. I shoulve known it was gonna need a new starter when I first started it... It kinda struggled a little bit but I thought nothing of it since it had been sitting for so long.
masamu6012 is offline
Old 11-05-2011, 02:09 PM
jesse1125
jesse1125's Avatar
I'm glad you got it figured out and back on the road. Enjoy
jesse1125 is offline
Old 11-05-2011, 02:19 PM
mustangGT86_05
Sounds like it was dragging, glad you figured it out.
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Bad Alternator?
