headers red hot??? why?
Old 11-08-2011, 11:45 PM
latinmustang90
latinmustang90's Avatar
Default headers red hot??? why?
I just replace my engine and ran ok but my headers are turning red hot I have no clue why is something wrong with the engine please aprecciate any info thanks.....
latinmustang90 is offline
Old 11-09-2011, 11:42 AM
mustangsneverdie
mustangsneverdie's Avatar
Do you still have the converters on your car? you need to check and see if they've been clogged. check fuel pressure and timing make sure everything is where it should
mustangsneverdie is offline
Old 11-09-2011, 12:00 PM
Jimk8067
Jimk8067's Avatar
If you still have your emissions equipment your air pump might not be diverting TAB/TAD problem. Did you disconnect the vacuum lines when installing the headers? Is it running ok? not missing or blowing black smoke is it? plug wires on correct? Or a clogged convertor problem.
Jimk8067 is offline
Old 11-09-2011, 12:06 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Only two real reasons why your headers would glow.
Timing is too retarded or you're burning too rich.
Derf00 is offline
Old 11-09-2011, 04:44 PM
AdderMk2
Banned
AdderMk2's Avatar
100% check your timing...
AdderMk2 is offline
Old 11-09-2011, 08:14 PM
latinmustang90
should I perform the TDC again? Im not sure if I did it right could that be the problem?
Old 11-09-2011, 09:19 PM
AdderMk2
Banned
AdderMk2's Avatar
yep... go read my how to, and try again
https://mustangforums.com/forum/5-0l...stributor.html
AdderMk2 is offline
Old 11-09-2011, 09:28 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Timing............fix it
projectresto83 is offline
Old 11-09-2011, 11:32 PM
tinman
tinman's Avatar
An extreme lean condition can also cause but I sooner think its the timing.......
tinman is offline
Old 11-10-2011, 12:14 AM
latinmustang90
Default it's fix
it's fix thank you so much guys!!!!! now what I have to work on next is the oil leak from the oil pan I just noticed again thanks guys
Quick Reply: headers red hot??? why?
