Fuel Injectors
#22
Fuel Injectors
thats pretty much it,
hey you might be able to program the EEC for 24# injectors,
but i think you should get away from the 50mm maf with the other goodies you have.... <edited><editID>bmorrisj</editID><editDate>37964.182650463</editDate></edited>
#23
Fuel Injectors
Seems kinda dumb they made these 5 pin flows then dont make aftermarket products for them. But thanks a lot man, you've helped me out a lot. </P>
From C&L should I buy there entire kit, or just the sensor, Ive got a cold air induction kit already</P><edited><editID>Milky</editID><editDate>37964.1849652778</editDate></edited>
#28
#29
Fuel Injectors
one last thing, you might want to check the O2 sensors,
1) The fuel mixture reads "rich" (i.e., too much fuel in the air / fuel mix)
2) Your car idles rough
3) High emissions output (can fail inspection)
4) Your check engine light goes on
5) Hesitation, stalling, surging and oscillating RPMs
some symptoms from http://home.nc.rr.com/rocketsmustang/frame.html
#30
Fuel Injectors
I don't know how to check them but I should because I do have that rough idle... My engine light doesn't go on - but thats broken. Im not sure if the engine light bulb is burned out or if its just turned off somehow. </P>
Im hoping that fixing the air meter will fix the rough idle, and if not at least help. If it doesnt help Ill look at the O2 sensors next I guess.</P><edited><editID>Milky</editID><editDate>37964.5139467593</editDate></edited>
