motor went under water with irene-cleaning motor
Old 12-09-2011, 10:56 AM
88GTBLACK
88GTBLACK's Avatar
Default UPdate: tranny went under water savable?
Water went in the intake -flood waters up to windshield-
had car about 4 feet off the ground still wasnt enough..
drained gallons and gallons from drain plug before oil started coming out.
pulled sparkplugs
water started coming out LOL
i turned engine over via breaker bar water gushed out of all 8 cyl holes
filled cylinders with WD40.
and its sat since.
starter is ruined it wont turn it over.
is the engine still salvageable?
without tearing it down?
somehow, everything still works in this car.
lights and all. i want to get it running.
88GTBLACK is offline
Old 12-09-2011, 12:03 PM
Tony71502
Tony71502's Avatar
I'm sure you could get the engine running by replacing a few things like the starter and maybe the solenoid if its bad, but I wouldn't do it. It may or may not fail on you. Not to mention I'm sure oxidation has already started inside the engine. Rusty cylinder walls aren't good. All the areas with electronics should be taken apart and cleaned before the connections corrode. Your carpet should be pulled up and dried before mold grows. Things of that nature.
Tony71502 is offline
Old 12-09-2011, 12:22 PM
ttocs
ttocs's Avatar
the motor will be the least of your troubles as all the electrical connections are corroded and will now continue to do so...
ttocs is offline
Old 12-09-2011, 12:58 PM
mattdel
mattdel's Avatar
I'd cut your losses and see if you can sell it, honestly. Cars that get swamped like that usually start having electrical demons that never go away.
mattdel is offline
Old 12-09-2011, 03:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
yup
mjr46 is offline
Old 12-09-2011, 05:10 PM
88GTBLACK
88GTBLACK's Avatar
Its a parts car with no title. I bought it this way. I wanna sell engine. Or maybe even use it. Wd40 soaked in there shod do the trick? What if i start it
And
Theres surface rust on walls. Will that totally destroy rings?
Old 12-09-2011, 06:07 PM
capri debris
capri debris's Avatar
Originally Posted by 88GTBLACK
I wanna sell engine...... there's surface rust on walls.
I pity the poor shmuck who ends up that engine. And mental note to self.... never buy anything from username 88GTBLACK.
capri debris is offline
Old 12-10-2011, 12:20 AM
tinman
tinman's Avatar
The water in those cylinders will rust and eat the rings right out of it.
I'll bet they are gone now.
V-8 engines aew wonderful things but they are not submirseable..........
tinman is offline
Old 12-10-2011, 07:47 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Your motor is done....simple as that
What you need to do so you have as little of issues as possible is to completely tear the car apart and pull the whole electrical harness out, strip it down for inspection and retape it...cleaning everything.
projectresto83 is offline
Old 12-10-2011, 09:11 AM
ttocs
ttocs's Avatar
wd40 is good but it isn't going to make helen keller see/hear/speak, nor save that motor.....
ttocs is offline
Quick Reply: motor went under water with irene-cleaning motor
