ok, another question about rear brakes..
Old 12-14-2011, 06:48 PM
302darrell
302darrell's Avatar
Lightbulb ok, another question about rear brakes..
ok, speeding down the rd i get caught at a red light.. im on the brakes moderately hard.. the *** of my 95 mustang is way up in the air.. like a mare in heat. car has none e brake. so is it normal for the car to act like there is no rear brake? is it some how related to the lack of e brake? this is my first mustang.. so im trying to learn what the norm is on these beasts.. thanks in advanced!
302darrell is offline
Old 12-14-2011, 07:00 PM
bluebeastsrt
bluebeastsrt's Avatar
The rear brakes only do about 10% of the work so if you were haulin *** it's normal. Could also mean your suspension is getting tired.
bluebeastsrt is offline
Old 12-15-2011, 08:57 AM
302darrell
302darrell's Avatar
yea im sure its the suspension wore out.. it aint ever been changed. is there a some sorta adjustment for the e brake under the car on this 95 gt?
Old 12-15-2011, 01:36 PM
mattdel
mattdel's Avatar
Rear brakes do about 30% of the work.
What you're experiencing is called a nose dive, caused by the front brakes engaging before the rears. The proportioning valve is supposed to send fluid out back first, and when the pressure builds in the rear lines(they're engaging), the valve then opens up the front lines. This prevents nose dives, assuming your brake system works properly.
Having no e-brake is a symptom that goes together with the nose dive. I'd say you might have a couple bad calipers out back.
mattdel is offline
Old 12-15-2011, 01:55 PM
Derf00
Gentleman's Relish
Derf00's Avatar
As stated, front brakes provide about 70% of the stopping power.
When you say you you have no e-brake, you mean no rear brakes at all?
Nose diving the way you did either way is common if your shocks or springs are shot.
Witht he car parked, go to each of the four corners of your ar and bounce the car a bit. It should bounce once. That's it. If the car "floats" or keeps moving more than one bounce, replace you're shocks, problem solved.
Derf00 is offline
Old 12-16-2011, 08:31 AM
302darrell
302darrell's Avatar
well guys i do know why i dont have a e brake... the cable from the handle to the little contraption that balances the pull on the rear e brake cables. is missing.. thats right cable and the balancer thingy is gone.. where could i score a good used one?
Old 12-16-2011, 08:46 AM
Tony71502
Tony71502's Avatar
You can find them at a junkyard or a parts company like latemodelrestoration. The parking brake has nothing to do with nose dive, though. Your hydraulic part of the brake system is bad or your suspension is shot.
Tony71502 is offline
Old 12-16-2011, 04:58 PM
302darrell
302darrell's Avatar
junkyards around here in lakeland fl dont seem to have one mustang..
Old 12-17-2011, 06:14 PM
eb2gt
eb2gt's Avatar
try prestige in Ga.
It might be possible that you have no rear brakes period if the cables are gone.
pull your rear wheels and take a look to make sure the brakes are there. I have seen worse things on second hand Mustangs........don't know why but people have a tendincy to remove things.
eb2gt is offline
Old 12-17-2011, 09:16 PM
Jfsram
Jfsram's Avatar
Considering what new parking brake cables cost. Buy new ones.
Jfsram is offline
Quick Reply: ok, another question about rear brakes..
