rear end whine
Old 01-14-2012, 06:30 AM
92lxguy
92lxguy's Avatar
Default rear end whine
I have a 92 coupe I had a low pitch whine in the rear end so I took it apart and found that I had 3 bearings bad so I changed all the bearings in the rear end now I have a high pitch whine does not matter if I stand on it ,let off of if or maintaining speed i have taken this thing apart 3 times not can't figure it out
92lxguy is offline
Old 01-14-2012, 08:02 AM
AdderMk2
Banned
AdderMk2's Avatar
are you torquing everything to proper spec?
AdderMk2 is offline
Old 01-14-2012, 10:14 AM
enix187
enix187's Avatar
its in the backlash
enix187 is offline
Old 01-14-2012, 11:14 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
did you set new crush collar to spec taking account for a new bearing/ 16-29 inch lbs of rotational torque??
mjr46 is offline
Old 01-15-2012, 07:48 AM
92lxguy
92lxguy's Avatar
Yes put a new crush sleeve in torque every thing down to spec I'm at 27" pounds on the crush sleeve and I'm at .010 on the backlash
92lxguy is offline
mtgldr
02-03-2024 09:00 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
Quick Reply: rear end whine
