Edelbrock Performer rpm II Vacuum Lines
Old 02-10-2012, 05:38 AM
slayton93
slayton93's Avatar
Exclamation Edelbrock Performer rpm II Vacuum Lines
Need a little bit of help with the Edelbrock Performer RPM ii EFI intake vacuum lines. Got the one under the plenum hooked to the far left of the vacuum tree, back of the intake to the pcv, and back of intake to fuel pressure regulator and one capped that goes to the egr because its deleted. When I unhook the one under the plenum it idles smooth as could be but the brakes get hard, when I plug it in, the car wont idle, back fires and surges on the idle, put a new tps in and did a base idle reset, please help me, pictures or walkthroughs would help a lot, thank you.
slayton93 is offline
Old 02-10-2012, 01:46 PM
enix187
enix187's Avatar
Sounds like a leak at your booster, are you saying you can leave the vacuum line unhooked and uncapped and it will idle correctly, or you have to cap the line for the booster for it to run right?
enix187 is offline
Old 02-10-2012, 02:00 PM
slayton93
slayton93's Avatar
i can leave it uncapped and unhooked and the idle is perfect
Omgitsa88Stang
10-05-2015 07:33 AM
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Edelbrock Performer rpm II Vacuum Lines
