any reason not to choose this cylinder head stud kit?
Old 03-08-2012, 08:08 PM
9550's Avatar
Default any reason not to choose this cylinder head stud kit?
i am under the impression that re-using head studs is a bad idea.
so, i checked summit
http://www.summitracing.com/parts/AR...4001/?rtype=10
i assume these are a better choice than bolts.
also, do you guys have a go-to parts supplier, or do you typically just shop around?
9550 is offline
Old 03-08-2012, 11:20 PM
tinman
tinman's Avatar
How do you get the idea that re-using head studs is a bad idea?
ARP is what most racers/builders are using that I know of.
ARP makes some real nice stuff, I've been using it for years.....
tinman is offline
Old 03-08-2012, 11:23 PM
9550's Avatar
i have heard it on more than one occasion that they stretch or something.
maybe what i heard was just for bolts?
im pretty sure what i have now is ARP, just dont remember if its studs or bolts
will find out soon i hope
9550 is offline
Old 03-08-2012, 11:30 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
torque to yield bolts are non reusable, arp bolts / studs can be reused many times
mjr46 is offline
Old 03-08-2012, 11:37 PM
9550's Avatar
that probably just saved me a bunch of money (assuming i am correct that i have ARP stuff)
thanks guys
(im guessing these torque to yield bolts you mention are the economy line?)
9550 is offline
Old 03-08-2012, 11:55 PM
mustangGT86_05
mustangGT86_05's Avatar
Yes you do NOT want to re-use torque to yield bolts. And no, they are not economy line, they are used out of the factory. The idea is they stretch to slightly change the thread pitch which will bind the threads. It is done to prevent them from backing off and loosen up, obviously you don't want your head doing that.
mustangGT86_05 is offline
Old 03-09-2012, 08:43 AM
ttocs
ttocs's Avatar
If you have ever had a broken bolt that you struggled to get out you will not even question the price on a good set of bolts. ARP is great stuff.
ttocs is offline
Old 03-09-2012, 10:15 PM
tinman
tinman's Avatar
If your bolts/studs are ARP, that will be stamped on them very clearly.......
tinman is offline
Old 03-09-2012, 11:55 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
the main points are already said..BUT do you really need to spend 3x as much on studs when regular bolts do just fine...
what are your plans on the motor?
projectresto83 is offline
Old 03-10-2012, 05:54 AM
9550's Avatar
at approximately 11:15 last night i was driving in my car thinking about these studs, then i was like, wait, how will i know if what i have are ARP or not?
i came here and saw this post. amazing.
thanks
9550 is offline
Quick Reply: any reason not to choose this cylinder head stud kit?
