Not getting up to temperature
Old 03-22-2012, 10:52 AM
replica
replica's Avatar
Default Not getting up to temperature
Just bought a 95 5.0 and the only mechanical issue is that the car doesn't get up to temperature. The temperature might get to the "N" on normal if I'm lucky. The car will get to the N, then the radiator fan kicks on and knocks it down to about the first little line on the gauge (even colder.) So I'm guessing the fan relay or whatever is operating, and the thermostat is operating since it's making the fan kick on. The exhaust smells a bit rich as well. Guesses on what's broken? I was thinking of replacing the ECT for fun. I do not have any CEL's.
Where does the temp needle generally point on a properly operating Mustang?
replica is offline
Old 03-22-2012, 12:19 PM
mattdel
mattdel's Avatar
Sounds to me like it gets up to temperature just fine. Your gauge is malfunctioning.
Sender, wiring, gauge.
mattdel is offline
Old 03-22-2012, 12:21 PM
replica
replica's Avatar
Is there a specific name for the sensor that sends the temp reading to the gauge?
replica is offline
Old 03-22-2012, 12:57 PM
mattdel
mattdel's Avatar
coolant temp sender, front driverside of the intake manifold.
mattdel is offline
Old 03-22-2012, 01:16 PM
replica
replica's Avatar
This guy?
http://www.autozone.com/autozone/par...47389_0_18589_
replica is offline
Old 03-22-2012, 01:45 PM
mattdel
mattdel's Avatar
Negative. SenDer, not senSor.
mattdel is offline
Old 03-22-2012, 01:47 PM
mattdel
mattdel's Avatar
http://www.autozone.com/autozone/par...28785_77401_0_
mattdel is offline
Old 03-22-2012, 01:59 PM
replica
replica's Avatar
Ah, thanks. The names change on the autozone site. They called it a switch, instead of a sender.
Thanks again.
replica is offline
Old 03-22-2012, 02:13 PM
mustangGT86_05
mustangGT86_05's Avatar
Yeah parts stores are weird like that, I worked at one a while back and they all change what they want to call things. Makes it a pain
mustangGT86_05 is offline
Old 03-22-2012, 05:44 PM
ttocs
ttocs's Avatar
mine was doing the same thing for about a year. Last year I did a HCI swap and got some aftermarket gauges just to make sure everything was safe. The new temp gauge shows it is working perfectly.
ttocs is offline
Quick Reply: Not getting up to temperature
