do i really need bigger injectors for my setup, everything is in my SIG. Guy from the dyno shop said im going to run those 24# lean, and i should go with a set of 39 or 30#. I dont want to go to big
with what's in your sig you don't need 30's and if your tuner had a clue on tuning he'd of been able to show you why if at all that you needed bigger inj's by referencing the A/F vs rpm on the graph and if it started to go lean at higher rpms, that would be an indicator of needing larger inj's......was an a/f graph even done at the tuner???
If you want different injectors, why won't you get some explorer 24# injectors. they have 4 spray nozzles compared to the 24#ers you have have 1 spray nozzle.
He told me I needed bigger Injectors before the car was on the dyno. I told him to do it anyways cuz I didnt drive all the way up there for nothing. Then I found out I had the wrong computer and couldn't do it anyways.
