passenger side valve cover clearance issues?
Old 08-23-2014, 01:49 PM
9550's Avatar
Default passenger side valve cover clearance issues?
i *think* i remember when i took the stock passenger side valve cover off that there was a thinner gasket installed when compared to the driver side. as i am putting stuff back together, just as a test, i put the passenger side cover in place without a gasket and i saw there may be a problem with clearance near the alternator (i didnt force it because i didnt want to screw up the paint on the cover). i am also concerned there may be a clearance issue with the underside of the upper intake and the egr etc.
the gaskets i have are pretty thick cork, 3/16".
so, is there a known issue with the passenger side covers? is it solved by a thinner gasket, or do we put the cover on with just rtv or something?
thanks in advance for any input
9550 is offline
Old 08-26-2014, 04:21 PM
Boss_Hotrod
Boss_Hotrod's Avatar
I would think they would be the same. Look at getting something other than cork. I got some rubber ones with metal cores that are supposed to be close/better tan OEM from Fel-pro. You can get them at any parts store.
Boss_Hotrod is offline
Old 08-27-2014, 06:02 PM
Raphs50
Raphs50's Avatar
The gaskets should be the same. If you have clearance issues with the upper intake/throttle body, you can add an intake spacer to gain a little clearance. That is what I did when I installed TrickFlow heads, since they were taller than stock.
Don't know about alternator clearance. My alternator is mounted lower with the Vortech SC.
Raphs50 is offline
Old 08-27-2014, 07:53 PM
9550's Avatar
thanks guys
i will let you know how it turns out
9550 is offline
Old 08-28-2014, 01:33 PM
prbxfd7
prbxfd7's Avatar
See if you can get a spacer for the upper intake. Or double up on gaskets in between the upper and lower intake? Let us know how you make out.
prbxfd7 is offline
Old 08-28-2014, 03:12 PM
bluebeastsrt
bluebeastsrt's Avatar
It's a very tight fit to the altanator but if it fit when you took it off it'll fit when it goes back on. Just use a little finesse and not a hammer.
bluebeastsrt is offline
Old 08-29-2014, 08:32 AM
9550's Avatar
right, but this is why i was asking about needing a thinner gasket on the passenger side. looks like the lip of the cover might be hitting the alternator, but a thinner gasket may drop it enough to miss the alternator.
9550 is offline
Old 08-30-2014, 10:31 AM
bluebeastsrt
I had the same issue with the trick flow valve cover. Is it coming close to the mounting bolt or the actually altanator body? With my issue it was coming close to the mounting bolt so I used a button head bolt for added clearance on the altanator mount. Sometime you have to get creative. And if that means buying the thinest set of gaskets to use then so be it. But I obvisually wouldn't buy 2 sets of gaskets and have one side lower than the other if that's what your asking and unfortunately there isn't a huge difference between a cork fel pro $10 gasket(.188) versus an aramid fiber gasket that is.094 thick. I mean we're literally talking a thousandths of an inch .
YoungStangsMan
09-05-2015 07:01 PM
teeeeg67
09-01-2015 11:53 PM
mtxplod
08-29-2015 01:43 AM
inyadreems
08-21-2015 09:10 AM
kirk35
08-17-2015 08:42 PM
Quick Reply: passenger side valve cover clearance issues?
