Transmission Compatibility
Old 09-25-2012, 05:11 PM
cholericfc
cholericfc's Avatar
Default Transmission Compatibility
My world class T5 transmission is blown.
I need to know what transmissions will work..and what I will need to get
Does the aluminum driveshaft still work with these transmissions?
Will the 02' tranny from a GT work in my car? (i can get one for $400)
What modifications? What will need to be replaced?
cholericfc is offline
Old 09-27-2012, 08:14 PM
cholericfc
cholericfc's Avatar
Can you use an later tremec TKO or 3650 and convert it in order to work with a 90' mustang 5.0L??
Old 09-28-2012, 12:06 AM
furiousjoe
furiousjoe's Avatar
no it is not a direct fit. it could work, but you would need a different length driveshaft and a different bellhousing, perhaps a custom bellhousing. you'll spend way more money converting to a tr3650.
why dont you just replace with another t5? you can get a stock t5 for dirt cheap, you could rebuild yours to stock spec or even stronger. some companies will rebuild a t5 to hold 500hp, and most people agree the t5 is the smoothest shifting (ex: vs tko 600, t56 etc)
furiousjoe is offline
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
junior04
09-28-2015 10:53 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Transmission Compatibility
