Overheating Mystery
Overheating Mystery
Hey Guys,
I bought a '92 LX a few years ago with the original engine still in it. It ran okay, but had a problem with overheating in traffic or at idle. So, I did the usual things, new aluminum 3 row radiator, new hoses, water pump, ect. Still overheated. I then called my local Ford Racing dealer and bought a new 5.0L crate engine and put it in the car. Guess what...It still overheats in traffic and at idle with the hood down. With the hood up, it will idle for hours without overheating. It idles at about 900RPM. I've replaced the radiator cap within the last 24 hours and observed water flow through the radiator when the thermostat opened. Has anyone had a similar problem and solved it? I researched the forum, but was unable to locate a thread with a problem similar to mine in it. Could the old ECU be doing something to cause the problem? Is there something about the hood I need to look at ? Cowl vents? Anything?
Really appreciate the benefit of your experience,
steve
steve
what is the temperature reading that you think it is overheating? it is overheating just based on the gauge? in traffic, engine heats up and then cools down as you start moving?
did ypu install engine yourself? did you burp/purge the coolant system of air? (or purge...)
The temp guage has gone to red on one occassion. It has gotten VERY close to red on other occassions before I shut it down. On those occassions the air conditioner would blow hot air and the engine would develope a miss and start loosing power. I checked it with a laser yesterday and it got over 225 before I shut it down.
Yes, you are correct, if I stop in traffic (even at a long signal light on a hot day) it tends to get very hot very quickly. When I begin moving again, it cools down quickly. I should elaborate, I had a reputable shop install the motor in May 2009 and I have been trying to correct this problem ever since. I have driven it several thousand miles and it's performance is strong, except in traffic. I've taken it to Ford dealers and the local experts, but no one has solved the mystery. Sorry for the long post, but I want to be thorough so as not to waste your time.
steve
So you have a 3 row radiator (a bit overkill but ok), stock mechanical fan, replacement water pump, correct? What thermostat and has it been replaced? The first thing you need to do is get an aftermarket gauge on the car, troubleshooting an overheating issue with a factory gauge is useless.
Not trying to insult your intelligence but you mentioned you watched water flow thru the radiator. How did you do this? I'd always replace the thermostat first whenever I had cooling problem and 99 times out of 100 thats the fix. Second again just checking but you are mixing coolant with water right? Glycol cools better than water alone. Good luck with the issue.
steve
