93 GT Headlight issues
Multi switch is likely the cause.
You need this: http://www.latemodelrestoration.com/...Lever-Assembly
Then this: http://www.latemodelrestoration.com/...ector-Assembly
And this: http://www.latemodelrestoration.com/...Repair-Harness
Wire all that in, make sure it works proper like, then do this: http://www.corral.net/tech/maintenance/foglights.html
It might all seem like a lot to do, but if you don't, you'll continue to have this problem. The reason behind all of it can be read inside the last link.
That is some good tech info. One thing I would mention to take a quick look at is the ignition switch. Pull the plug and make sure that it has not burnt areas. also make sure that it is not seperating, the plastic part of switch to the metal part that rivets to the column. It has been a long time but I recall having some problems with mine in that area. Ford actually recalled alot of them back then. I dont remember if I had headlamp issues but I did have some electrical functions stop working from it. It was easy to replace. After i put the new ignition switch and plug in i zip tied the entire thing together to ensure that it could not seperate in the future. Never had another problem from it.
