Do theses cylinder heads look good?
Old 12-19-2012, 12:57 AM
gnx547
gnx547's Avatar
Default Do theses cylinder heads look good?
I'm tearing apart my engine to transfer the heads, intake, and cam to my new rebuilt short block. I removed the heads and the far right cylinder is pretty dark on both heads. Would this be that cylinder is running to rich? Or is this normal? There are no cracks in the head or valves and all the spark plugs looks normal on all cylinders. Also on the block, the passenger back 2 cylinders look different than the rest of the cylinders, and the driver side looks normal. On the pass side what kind of wear is that? Is this normal wear? What would cause that?
gnx547 is offline
Old 12-20-2012, 10:10 PM
mattkoly
mattkoly's Avatar
It may be possible that since the pcv suction originates at the back of the upper intake and there is the possibility small amounts of oil are being pulled by it, this is the result of this oil being burned?
did u check the compression prior to pulling engine?
mattkoly is offline
Old 12-21-2012, 06:55 PM
gnx547
gnx547's Avatar
No, I did not. The engine ran fine before I pulled it. Before I have been losing oil so I installed an oil separator along with a new pcv valve and a new metal mesh filter.
gnx547 is offline
Old 12-23-2012, 07:30 PM
mattkoly
mattkoly's Avatar
Do u have an aftermarket upper and lower intake?
mattkoly is offline
Old 12-23-2012, 08:05 PM
Venomantidote95
Venomantidote95's Avatar
Looks like those 2 cylinders were drinking some coolant, yes the one head looks to have a rich and or oily condition, as far as the pcv sucking oil and a certain 2 cylinders getting it all is a little farse but hey it could happen!
Look closely at the gaskets inbetween those cylinders and see if they are warped any if so that was your problem on those two!
Venomantidote95 is offline
Old 12-23-2012, 10:33 PM
gnx547
gnx547's Avatar
I have a Cobra upper and lower intake..I will take a look at the head gaskets and see if they are warped. So if the head gaskets are warped does that mean the head is not straight?
gnx547 is offline
Old 12-24-2012, 08:31 AM
Duncan_GT
Duncan_GT's Avatar
More than likely you were on the road to blowing the gasket. The head gasket may be warped just enough to where its sipping coolant in tiny amounts. You should replace it anyways since you took the heads off, I don't like reusing gaskets
Duncan_GT is offline
Old 12-24-2012, 10:24 AM
Venomantidote95
Well that is one that you dont want to reuse, but i have seen it done!
You will need to have the heads reworked about 150$ at the machine shop pending location, resurfaced and vlv job. (not necessary but smart)
A cast head can become warped or cracked but warping isnt normal cracking is more common in iron heads, the aluminum are more prone to warping.
Old 12-25-2012, 01:33 PM
gnx547
gnx547's Avatar
I looked at the head gaskets and both were straight, just the end part was a little distorted from taking the gasket off. I wasn't planning on taking the heads to the machine shop, just going to reuse them. So it is really necessary to get the heads and valves reworked?
gnx547 is offline
Old 12-25-2012, 07:11 PM
Venomantidote95
150$ worth of proper seal and compression! plus a multi angle vlv job promotes better flow too. yeah i`d say so but hey I only like to do things right! The first time.....
Quick Reply: Do theses cylinder heads look good?
