95 gt timing help
Old 02-02-2013, 01:24 PM
mustang_owner_302
mustang_owner_302's Avatar
Default 95 gt timing help
95 gt everytime i time my car ill pull it out of the drive way get on it an it screams then 3 mins later it loads up an starts poppin any ideas why? if i pull the block out for the computer that helps re adjust it it runs a lil better and cant figure out my problem i switched distributors replace tps sensor and iac thinkin that mite b part of the problem but its apparently not been tinkerin with it for the last week and a half the car has bbk ssi upper and lower intake, 75mm maf, afr185cc heads, stock cam, an 1.6 rr if that changes anything plz help, dont have the tab on harmonic ballancer so i hold throttle at 2500 an adjuct dizzy till it pops an back fires then back a 1/4 inch its always works before but is bein stubborn now
mustang_owner_302 is offline
Old 02-02-2013, 04:50 PM
LCBlackDep183
LCBlackDep183's Avatar
Does it stall at all? It sounds like possibly the spark delivery is inconsistent.
Have you tried replacing the ignition coil? When you swapped distributors did you replace the strator coil?
LCBlackDep183 is offline
Old 02-04-2013, 08:46 PM
packers9122
packers9122's Avatar
if u have an lil bit of money to throw around i would do plugs,coil,ignotion control module and make sure none of the plug wires are touching.are u pulling the spout when you time it.also dont forget to get the car at running temps before you do it.
packers9122 is offline
mungodrums
10-07-2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
09-28-2015 09:18 PM
StalkerGT
09-25-2015 02:41 PM
09-08-2015 11:50 AM
Quick Reply: 95 gt timing help
