radiator Fans
Old 04-11-2013, 03:51 PM
Maxwelhse
Maxwelhse's Avatar
Originally Posted by GTstangB.F.D.M.
thanks guys.. just picked up a markIII fan.. done a little research on installs for these.. im thinking just run a 70amp relay, 70amp fuse, and on/off switch.. no controller or any of that s.it
just want it simple and cheap. anyone see any issues with doing it that way?
I do... With that setup you have the option to forget to turn it on or off.
At least get one of the cheap automatic fan switches ($20). You can always wire up a manual switch as an over ride if you want.
Maxwelhse is offline
Old 04-12-2013, 09:58 PM
GTstangB.F.D.M.
GTstangB.F.D.M.'s Avatar
no a/c.. also, i was told the two black ground wires determine wether it pushes or pulls..
GTstangB.F.D.M. is offline
Old 04-12-2013, 10:17 PM
Maxwelhse
Maxwelhse's Avatar
Whether or not that is true (I never tried it since I always wanted mine to PULL), you NEVER want a fan to "push" against an obstruction (radiator) if you can at all help it.
The logic behind it? Air is compressible... When you "push" air with a fan you have about 15% efficiency loss due to that compression.
I know, once again I'm not answering the question that was asked, but pushed fans are bad mo-jo as far as cooling systems are concerned and are only, at best, a band-aid on a real cooling solution.
Old 04-13-2013, 10:02 AM
GTstangB.F.D.M.
well said. i plan to leave it 'pulling'.. BUT i was thinking, man if you really had cooling issues and need all you could get.. a small 12incher on the front 'pushing' paired with the puller on the back side.. that would really move some air! lol
however, it also seems kind of redundant. lol
Old 04-13-2013, 03:02 PM
Maxwelhse
Maxwelhse's Avatar
The only time I've seen a small pusher make sense is for A/C performance (or just flat out out of space to put something on the rear),
Generally a little fan out front of a big fan just acts as an air obstruction to the big fan behind it.
Old 04-14-2013, 03:19 AM
GTstangB.F.D.M.
makes sense.
Old 04-15-2013, 11:05 AM
GTstangB.F.D.M.
ok... again.. I'm lost.. trying to order the crap to wire this fan up.. including relay, wire, fuse, etc..
looking for help on the wiring aspect... PLEASE!
when wiring this, do i run lets say, 10 ga from battery to relay? and 10 ga from relay to ground? and then from relay to fan and switch can be normal 18 ga wire?
can't find any real info or help on this.. please let there be an electrically inclined God out there.
Old 04-15-2013, 04:57 PM
Maxwelhse
Maxwelhse's Avatar
The relay coil wiring is light duty (both power and ground) and the load wiring itself should be of sufficient gauge to run the appliance the relay is powering.
The ground from the fan itself should not be run to the relay at all.
Without trying to sound like a jerk, do you understand the basic principal of how a relay works and what you're actually using it for?
If you're not totally sure, go here and read: http://www.the12volt.com/relays/relays.asp
Pay careful attention to the part of the diode. Many high quality relays already include the diode, but many do not. Since your fan will be spinning under the force of wind, even when the power is off, it can induce a current that can spike the coil. As far as how big of a diode for X application and all that, you're gonna have to do some googling to get your answer.
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
Seanam
10-04-2015 10:15 AM
09-25-2015 09:06 AM
Beerman309
09-19-2015 01:16 AM
Quick Reply: radiator Fans
