Front rim grinding control arm
Old 07-07-2013, 06:25 PM
Goosepoop302
Goosepoop302's Avatar
Default Front rim grinding control arm
So my front passenger tire is rubbing on (my have this wrong) my control arm. car is lowered with adjustable C/C plates. It has been aligned by tires plus and I question there ability....anyway. It only happens on the one side of the car when turning the wheel hard right. It hits hard enough to have worn a flat spot on the inside of the rim. see pics..
Attached Thumbnails Front rim grinding control arm-img_20130707_172303.jpg   Front rim grinding control arm-img_20130707_172333.jpg   Front rim grinding control arm-img_20130707_172318.jpg
Goosepoop302 is offline
Old 07-07-2013, 06:38 PM
dawson1112
dawson1112's Avatar
Whats your front rim size ? those are not stock rims are they? and also how low did you go?
dawson1112 is offline
Old 07-07-2013, 07:14 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
backspacing may be wrong as they don't appear to be stock rims for that year
mjr46 is offline
Old 07-08-2013, 10:23 PM
Goosepoop302
I want to say they are 17x9, been a while...don't recall the width.
1.5 drop in front I believe
I haven't had issues as long as the rims have been there....this is something that started within the last year
Old 07-11-2013, 10:01 AM
Tony71502
Tony71502's Avatar
My 17x9 rims will rub if I turn all the way to the lock. I'm surprised it hasn't been happening the entire time the rims were on the car... unless you just didn't notice. Cheap fix is getting spacers for the steering rack. Expensive fix is getting tubular control arms. Or do what I do and just be conscious enough to not turn all the way to the lock.
Tony71502 is offline
Old 07-11-2013, 10:31 AM
AMWill
Former Sponsor
AMWill's Avatar
Goosepoop302,
If the rubbing just started and it's only on the driver side, then something has to be bent or warn out. Take the car to a shop have them assess the front suspension. It shouldn't take too long for them to find the issue once the car is on a lift.
Good luck!
Shane
AMWill is offline
poke68
12-15-2015 06:25 PM
Gene K
10-21-2015 11:37 PM
guitarman376
10-11-2015 01:47 AM
FivePointToTheOh
09-14-2015 03:35 PM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: Front rim grinding control arm
