Need a little help
Need a little help
I was doing a tune up on my 95 5.0 changed plugs and everything. I wanted to adjust my timing so i remove the spout connector to time it.. well after that i forgot to plug it back in and as luck would have it i lost the connector. Does anyone know where i can get another one or what i can do.
That spout is just a jumper .
You can use a pies of coat hanger if you wanted to to make the connection. Or you can cut the plug out and wire in a switch that can be switched on or off to make the connection . On=spout in off = spout out.
