Need some help
Old 07-15-2013, 06:19 PM
Gagestang
Gagestang's Avatar
Alright, so I start the car up , car idles and runs good, so I drive down the road and shift at 3000rmp and its fine, then if I rev the car over 4000 when I shift the car will start to over heat after about 5 mins after being ran hard and stay hot , it has a 180degree thermostat in it ,
Gagestang is offline
Old 07-15-2013, 06:21 PM
Gagestang
Gagestang's Avatar
I know it sounds crazy , that's why I'm looking for some help , I have never seen any of my past mustangs do this
Old 07-15-2013, 06:40 PM
dawson1112
dawson1112's Avatar
How was your head gasket checked?
dawson1112 is offline
Old 07-15-2013, 07:09 PM
Gagestang
Gagestang's Avatar
We used a block tester
Old 07-15-2013, 07:36 PM
Duncan_GT
Duncan_GT's Avatar
Are they new head gaskets?
Duncan_GT is offline
Old 07-15-2013, 07:44 PM
Gagestang
Gagestang's Avatar
I'm not sure i just got the car about a week ago
Old 07-15-2013, 07:52 PM
dawson1112
dawson1112's Avatar
So you ran the cylinders up to around 120 psi with the block tester?
Im not so sure I would rule out a head gasket that is starting to fail .
Get a kit from autozone or similar that check for the presence of carbon monixide in the antifreeze.
When the cylinder fires it is pushing far more than any tester can run up to especially at high rpms.
Old 07-15-2013, 10:24 PM
Gagestang
Gagestang's Avatar
The block tester they gave me was a liitle tube looking thing with some blue liquid , And pumped it and it was supposed to turn yellow if their was a problem , and it turned green I didn't test the psi in the cylinders ,
Old 07-15-2013, 10:29 PM
dawson1112
dawson1112's Avatar
Ohh I got ya I was thinking of something else then. I think what you did was test for carbon in the coolant. You basically just sucked up the coolant and it mixed with that blue liquid.
Old 07-15-2013, 11:03 PM
Gagestang
Gagestang's Avatar
Maybe the radiator is clogged somewhere , or maybe a collapsed lower radiator hose
