ELECTRIC FAN HELP
Old 08-16-2013, 02:10 PM
88horserider
88horserider's Avatar
Default ELECTRIC FAN HELP
For those that have converted over to electric fans, what type of fan would you recommend to keep my mustang cool. It does have the usual cam, intake, aluminum heads, etc...
What are you guys running.... single or dual fans?
What size fan blade?
88horserider is offline
Old 08-17-2013, 07:02 PM
darkmach1
darkmach1's Avatar
A lot of guys pick up contour factory fans from a junk yard and add some type of aftermarket controller. I run a black magic 185 extreme with good results.
darkmach1 is offline
Old 08-19-2013, 11:53 AM
88horserider
Ok, thanks for that advise. I have an electric fan i picked up from a junk yard before i asked on here. It's working ok but i can tell it's struggling, i notice my heat creeping up as i go through town and it's running all the time.
Old 08-22-2013, 06:10 PM
BIGTY2009
BIGTY2009's Avatar
The contour dual fan set up is great. I just hooked one up to mine I would say a month ago, give or take. I run a 331 stroker, high lift cam, the works. At the same time I also installed a 180 t-stat, my gauge never creeps a millimeter over even after beating on her. The fan enclosure fits dang near perfect over the stock radiator and mounts pretty simply.
BIGTY2009 is offline
Old 08-27-2013, 12:17 PM
88horserider
Thank you for that advice... its off to the junkyard for me lol. im not sure what the one i have comes off of because the junkyard i got it from had a pile of fans laying there so i didnt have to take it off. i will let you know how the contour fan works out for me.
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
Seanam
10-04-2015 10:15 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
Quick Reply: ELECTRIC FAN HELP
