New engine problems.
Old 08-27-2013, 08:56 PM
Cobra509
Cobra509's Avatar
Default New engine problems.
Build list,
302 block from latemodelrestoration bored .30 over
e303 cam, 1.6 rockers
comp heads, 2.02 valves
65mm throttle body
Everything else is stock except the bbk headers and bbk x-pipe and msd ignition.
So the problem is the temperature keeps spiking at idle and normal driving but while under WOT the temp drops to normal and we can't seem to time it right, we had it 10 degrees before and the car liked it only when you were WOT
Also would i have to gap the spark plugs any different from stock, and do i need to change anything in the fuel system or a maf for more air?
Cobra509 is offline
Old 08-27-2013, 09:15 PM
dawson1112
dawson1112's Avatar
Still using the stock 19# injectors?
Do a koer test and see if you get any lean codes. My guess is your very lean.
dawson1112 is offline
Old 08-27-2013, 09:40 PM
Cobra509
Cobra509's Avatar
Ya I got the orange injectors, seems like its not getting enough fuel or air
Cobra509 is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
Pyrate Dave
09-10-2015 07:30 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: New engine problems.
