Turbo or not turbo? Someone read this and answer
I have an 87 ttop gt.. I am wanting to buy a holset h2 turbo setup on cl to put on my car..(actually trading a badass wrecked Mercedes for it that I don't need so it's not costing anything)... What do you guys think? It was made for a foxbody so it shouldn't be hard .. What kind of gains should I expect? This is what's been done to my car.. . 87 mustang gt with ttops. Bbk cold air intake, bbk long tube headers, and bbk 75 mm throttle body,.. Fuel pressure regulator with gauge .. edelbrock Victor upper and lower intake.. afr 185cc aluminum heads... Flex-a-lite dual electric fans.. 3 core aluminum racing radiator..optima red top battery..coast high performance 347 stroker kit with all forged crank, rods, and pistons...full roller motor with aluminum 1.6 rockers... trick flow stage 2 cam.. tremec tko 500 trans... aluminum driveshaft.. svo rear end with maximum motorsports rear lower control arms and sway bar...3.55 gears.. Aftermarket rims with nitto 555r drag radials...msd 6al ignition, cap, coil and plugs ... underdrive pulleys... Paxton fuel pressure regulator.... Sure there is more I'm forgetting..
Its a holeshot h2...From what I understand its comparable to an hx50 pr 60? Idk much about them but heard they are pretty good.. Car arrays has power and I don't want to crack the block or anything but turbo sounds fun
Golfsito
10-06-2015 11:02 AM
