92 5.0 mustang over heating need help
Old 09-11-2013, 07:03 PM
mn102483
mn102483's Avatar
Default 92 5.0 mustang over heating need help
I have a 92 mustang with a 5.0 that has holly aluminum heads and a b303 cam and it is over heating this all started after I got the car dyno tunned I drove it home about 45 min drive and when I got in my garage I noticed that it was over heating gauge was all the way up . bought a new thermostat and still over heated took thermostat out completely and still over heated it boiled over then thermostat gasget blow . bought a block test kit to see if maybe head gasget was blown due to getting it dyno tunned at least that's what the shop said it could be that test was neg. liquid did not turn color . I am at a dead end radiator is new water pump is fairly new and water seems to be circulating fan clutch seems to be working . only other thing I can think of is when the shop did the tune they also set the timing maybe timing is set too high can this cause over heating . please help me don't want to take motor apart to do a head gaskit thank you
mn102483 is offline
Old 09-11-2013, 07:07 PM
mn102483
mn102483's Avatar
car was running cool before the tune
mn102483 is offline
Old 09-11-2013, 08:31 PM
88 orangepeel notch
88 orangepeel notch's Avatar
Advancing timing does create more heat, but not near enough to cause what your describing. Did they burn a chip for your ECM, or did they just advance timing with distributor? So car will still overheat even at highway speeds?
88 orangepeel notch is offline
Old 09-11-2013, 08:38 PM
mn102483
mn102483's Avatar
the car was chiped and noticed it over heating when I got home I have not driven the car since but over heats at idle
mn102483 is offline
Old 09-15-2013, 05:02 PM
mn102483
mn102483's Avatar
new update messed around with car today and rised up feul pressure to about 40psi and lowered the timing car stoped over heating but now runs like **** serges real bad and in rearvers it shuts off if I don't give it a lot of gas it cranks a lot before starting but when I but timing back to where it was it starts to get hot any ideas
mn102483 is offline
Old 09-15-2013, 05:23 PM
Goosepoop302
Goosepoop302's Avatar
what is the base timing your running at? I would call the tuner and let him know your issues.. fuel pressure should be right around 40 psi
Goosepoop302 is offline
Old 09-15-2013, 06:13 PM
mn102483
mn102483's Avatar
the shop set the timing don't know what they had it at but I had a mark on it where it was before I took it to the shop and car wont over heat when I put it there
mn102483 is offline
Old 09-15-2013, 06:14 PM
mn102483
mn102483's Avatar
the place I got it tunned said its probly a head gasket and wants 1100 bucks to fix
mn102483 is offline
Old 09-15-2013, 08:06 PM
Goosepoop302
you in MN? if it was cooling fine before the tune I would be surprised if it was a head gasket. have you changed the oil or anything? does it kick out colored smoke?
Old 09-15-2013, 10:53 PM
darkmach1
darkmach1's Avatar
"Probably a head gasket" and they want 1100 to fix it? Tell them to go pack sand.
darkmach1 is offline
Quick Reply: 92 5.0 mustang over heating need help
