valve covergasket install
Old 09-27-2013, 01:47 PM
fullmonte60
fullmonte60's Avatar
Default valve covergasket install
I was removing upper intake and when I went to take out the back passenger side bolt I saw that this bolt has a threaded stud coming from the top of it and that a nut clamps down the flat end of a piece of pipe. the pipe doesn't slide off easily and I don't want to break it by yanking it off. anyone run across this? its to the right of the 2 electrical hoses. thank you.
fullmonte60 is offline
Old 09-27-2013, 11:26 PM
fullmonte60
dug a little deeper with a better light and mirror. the other end goes to the lower intake, driver's side rear bolt/stud, #8 in the torque sequence. in alldata, it shows the stud/bolt on the upper but not the similar type where it connects on the lower. and it doesn't show the rod between the 2. pretty safe to say the upper hasn't been off before. wonder what the purpose of that rod is?
Old 09-28-2013, 10:07 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
can't tell by the pic you have, what rod??
mjr46 is offline
Old 09-28-2013, 11:29 AM
Duncan_GT
Duncan_GT's Avatar
Need a better picture, I don't see what you're talking about
Duncan_GT is offline
Old 09-28-2013, 09:25 PM
fullmonte60
the rod connects the 2 studs I mentioned. 1 stud on the upper, 1 on the lower. maybe it was used during the assembly process while parts were a flying in the factory.
Old 10-01-2013, 09:24 PM
fullmonte60
let me try to get a better pic.
Old 10-18-2013, 09:04 AM
fullmonte60
the rod in the pic attaches the upper to the lower in the rear of both,
Old 10-19-2013, 09:31 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
yeah my car didnt have that when i got it...
rmodel65 is offline
mtgldr
02-03-2024 09:00 PM
TimeLord101
09-04-2015 09:27 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: valve covergasket install
