wont stay running. need help.
Old 10-01-2013, 06:56 PM
samltheriault
samltheriault's Avatar
Exclamation wont stay running. need help.
ok so i had a big project this winter in to the summer unfortunately and now its finally coming to an end as well as cruise time. i did a wire tuck. now the dam thing wont stay running unless i unplug my MAF sensor. i just got my new one in today calibrated and all for my injectors and so forth but it still wont stay running unless its unplugs. checked the wires coming to it and I'm getting a steady 12.4 or so volts from positive to negative and a 5.24 volts coming from the signal wires so everything seems ok there. what else could cause it not to run with the MAF plugged in. any other sensors that interact with the MAF sensor??
ps. it runs decent at idle when not plugged in and i can sill drive it around. running rich as all hell but still runs and drives. just has less power then it use to.
samltheriault is offline
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
NYstang
09-30-2015 09:56 PM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: wont stay running. need help.
