Help! Stalling at idle
My 94 5.0 stalls during parking when I go from drive to reverse and vica versa.
The idle speed is set to 550 to 600 rpms. Normal according to Haynes manual.
My question is... is there a common problem I should be looking at?
The manual says it could be a number of things including but not limited to: vacuum leak or emissions stuff.
Is there something that could have this effect and also cause the auto trans to shift 3-4 too soon? (my guess would be vacuum leak)
Any help here would be appreciated.
Ok, I did that. Works better now.
I looked under it for the first time since buying it and discovered a crap load of leaks.
Looks like a rear main seal, trans tail shaft seal, oil filter, both ends of the lower rad hose, and maybe the transmission pan.
The guy must have washed it before I looked at it. I didn't see any of that then.
Looks like I got some work ahead of me.
