Clutch fan vs. Dual Electric
Old 11-25-2013, 06:44 AM
yurizx6r
yurizx6r's Avatar
Default Clutch fan vs. Dual Electric
Hey guys, my stock fan blade is cracking bad, so it's time to make a choice. I was looking at possibly just swapping out the stock blade, or getting a Mishimoto dual electric fan assembly. Have you guys noticed any difference with these? How would you wire them? Any advice? Thanks in advance!
yurizx6r is offline
Old 11-25-2013, 07:32 AM
dawson1112
dawson1112's Avatar
You can get a duel fan assembly from a Contour V6/Cougar/Mystique. the duel fan assembly was used on those cars that had v6 engines. The thing will literally be a perfect fit over your stock radiator. And will be much cheaper.
http://www.ebay.com/itm/Contour-V6-Cougar-Mystique-V6-Radiator-A-C-Fan-Assembly-Dual-Fan-/131031006538?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AMercury%7CModel%3AMystique&hash=item1e820e7d4a&vxp=mtr
To wire them you need a duel fan relay. such as this one.
http://www.ebay.com/itm/American-Auto-Wire-DUAL-FAN-RELAY-KIT-Relays-40-/331058615044?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d14a19304&vxp=mtr
dawson1112 is offline
Old 11-25-2013, 09:49 AM
yurizx6r
yurizx6r's Avatar
1st off thank you for that information! 2nd, is that the best relay to get and is it temperature controlled?
yurizx6r is offline
Old 11-25-2013, 08:10 PM
mebirkle
mebirkle's Avatar
wow, is there a thread on how to install this setup? I'm looking to spend about 600 on a black magic setup with controller.
Do you have this exact setup?
Thanks@
mebirkle is offline
Old 11-26-2013, 10:16 AM
mebirkle
mebirkle's Avatar
Contour V6 Cougar Mystique V6 Radiator A C Fan Assembly Dual Fan | eBay
American Auto Wire Dual Fan Relay Kit Relays 40 | eBay
Hi, I see that the fan mounts are on the side of the fan, however, the mounts for the stock shroud are at the top and the bottom. Is there a mounting kit that is needed for this fan setup?
Thanks again for your help dawson1112!!!
mebirkle is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
Thunderball
15
11-22-2015 11:49 PM
folivier
10-02-2015 05:34 AM
junior04
09-28-2015 10:53 AM
Quick Reply: Clutch fan vs. Dual Electric
