My New 1990 Mustang GT, Lots of questions
Old 01-21-2014, 07:35 PM
Ballistics
Ballistics's Avatar
http://treperformance.com/i-9214812-...l-stage-2.html
This kit says it will make 400fwhp. This is assuming that I have an after market intake?
Or this kit alone will get me where I want to be?
Ballistics is offline
Old 01-21-2014, 08:12 PM
aode08
aode08's Avatar
Originally Posted by Ballistics
So what would it take to actually get 330 to the wheels?
Ill help you out,
an engine is like a air pump, the more air it can suck in and exhale the more power.Your 306 will start the process of walking main cap bearings,breaking push rods to the valves, because your going to have to spin high rpms to get more power.
aode08 is offline
Old 01-21-2014, 08:34 PM
Ballistics
Ballistics's Avatar
Originally Posted by aode08
Ill help you out,
So what do I need to do?
Old 01-22-2014, 08:34 AM
aode08
aode08's Avatar
If you don't mind a high compression setup, than a high compression setup could pull it off.
The first thing would be to find out, what (cc)pistons are in your 306 to determine what top end kit would be appropriate.
High compression will require you to use felpro head gaskets , head studs not bolts.As well as the thicker rocker studs, not the wimpy skinny ones.And true roller rockers, not the cheap ball style.
After that, the drag of the stock pulleys should be changed to under drive pulleys with belt, the water pump fan clutch has to go,you'll need an electrical fan setup, easy.As well as an aluminum drive shaft to be installed.Your going to need as little rotating mass as possible.
Then to handle the high compression, your spark plugs,spark plug wires, coil pack has to be upgraded so the spark does not blow out..
I can walk you through the entire process, its what I do.Very easy, just the top end kit cost the most.
aode08 is offline
Old 01-22-2014, 05:04 PM
Ballistics
Ballistics's Avatar
I'm assuming I'd have to take it to someone to look at it, to find that out.
I appreciate any and all help I can get . Thank you.
Old 01-22-2014, 06:34 PM
aode08
aode08's Avatar
No just me is all you need,
you can pull a spark of out of cylinder one on the passenger side front most plug, shine a light, and maybe take a picture with your cell phone camera,or here is a chart, let me know what you see, this is easier to see the piston at night
http://www.coasthigh.com/Ford-306-en...ts-s/13041.htm
Just let me know the number of the piston and name off this list
Once we find that out, ill give you a complete parts list, you just buy and instal.Ill include several setups to save you money, maybe you can find used stuff on here, your local Craigslist, ill walk you through any installation question you may have.
You see because if you go trick flow, and some other heads, you'll smack the valves into the piston if its the wrong piston
aode08 is offline
Old 01-22-2014, 08:19 PM
Ballistics
Ballistics's Avatar
That's what I like to hear lol.
I'll do this asap.
Old 01-25-2014, 07:41 PM
65Raven65
65Raven65's Avatar
Man, that video makes me miss my '89 GT!
I've got nothing useful to add, but congrats, great looking fox!
65Raven65 is offline
Old 01-26-2014, 03:48 PM
Ballistics
Ballistics's Avatar
Thanks Raven.
AODE, I'm off Tuesday so I'll be able to get that info.
It's looking like I'm going to go with
AFR185s
RPMII Intake
XE270 cam
70mm Throttle body
Old 01-26-2014, 04:00 PM
GTgeezer
GTgeezer's Avatar
Very nice looking Fox. looks clean. bet it's very fun to drive.
GTgeezer is offline
Quick Reply: My New 1990 Mustang GT, Lots of questions
