5.0 no idle cold and backfires. PLEAE HELP!
Old 04-21-2014, 04:05 PM
5overt
5overt's Avatar
Default 5.0 no idle cold and backfires. PLEAE HELP!
Ok guys I am fighting the same monster here. It wont idle at cod start have to start 4 or 5 times and keep working the throttle to get it to run. Once it does idle when I pop the throttle it backfires, and I can hear a slight miss. car runs rich as hell (eye watering rich) codes are all air bypass etc. thats all removed. I have put wires cap rotor. Cut out the ten pins and wired them straight. New TPS swapped in a good IAC. short ram air intake 2040 compucam and new o2 sensors. GUYS PLEASE ANY HELP IDEAS would be appreciated. computer maybe that my next idea.
5overt is offline
Old 04-21-2014, 07:01 PM
HACKGT350
HACKGT350's Avatar
double check your firing order
HACKGT350 is offline
Old 04-21-2014, 07:39 PM
5overt
5overt's Avatar
I have it runs good once I can get it warm. I have also put new fuel regulator on. one other thing I can here it sucking air when I punch it too. it suck thru the air filter but its loud. like woooof woof it almost hesitates when i punch it. I have two TPS i cant get more than .05 out either.
5overt is offline
Old 04-21-2014, 08:40 PM
5overt
5overt's Avatar
I got on .98 still does the same **** no change
5overt is offline
Old 04-23-2014, 09:10 PM
5overt
5overt's Avatar
what about injectors could that make it run rich?
5overt is offline
Old 04-24-2014, 02:47 PM
HACKGT350
HACKGT350's Avatar
injectors can make it run rich if they are staying open too long and they normally run a little richer on cold start till the engine warms up and the computer starts using data from the o2 sensors
Granatelli Sales
03-25-2016 08:01 PM
schecterplayer
09-23-2015 08:38 AM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: 5.0 no idle cold and backfires. PLEAE HELP!
