vacuum
Old 04-26-2014, 01:58 PM
michaela8456
michaela8456's Avatar
Default vacuum
white line comes out of the egr goes to a cluster of lines that run to strut tower there are three call them blocks that lines go to. the two bottom one there is a vacuum line that attaches to both of them where it runs to motor is capped off and i have a line that comes from resevoir inside fender well going no where can some one help hopefullly with a picture of where the lines are to go 1989 mustang gt HO 302 all stock thanks for any help.also what ia a VSS
michaela8456 is offline
Old 04-27-2014, 09:09 AM
ALMOST STOCK
ALMOST STOCK's Avatar
Sounds like someone has removed all the emissions solenoids and just capped the vacuum lines.
The diagram below shows you where those vacuum line go, and the line that goes into the passenger side fender goes to a reserve vacuum canister for the emissions solenoids.
VSS = Vehicle Speed Sensor. http://www.latemodelrestoration.com/...g-Speed-Sensor
ALMOST STOCK is offline
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
Ipaman
09-22-2015 07:01 AM
SteelerNation82
09-16-2015 07:11 AM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: vacuum
