91 GT Strange idle issue after throttle pressed???
Old 05-02-2014, 08:53 PM
MacSerio
MacSerio's Avatar
Default 91 GT Strange idle issue after throttle pressed???
FIRST OF ALL: I was having issues with egr system, the line that connects to the egr valve was having constant vacuum. I cleaned it out and it started working properly. The next day, it started doing the same thing. The vacuum came back on the line that connects to egr, it stopped after i cleaned it the first time but now its sucking air again....What causes this?
SECONDLY: And my idle is pretty steady at about 7rpm if i start the car with that egr line unplugged, but as soon as i hit the throttle once, the idle gets all screwed up and starts jumping around 6-7 rpm. If i turn the car off and immediately start it back up, the idle will be fine again; but as soon as i start driving or tap the throttle...bam the idle becomes eratic again. What should i look for or check. I cleaned out most sensors and checked all vacuum lines,, what else could it be?
MacSerio is offline
Old 05-02-2014, 09:06 PM
dawson1112
dawson1112's Avatar
That vacuum is supplied by the egr vacuum solenoid. You may need a new one.
A for the surging idle from 600-700 rpm you could have a vacuum leak and that solenoid may be the culprit.
dawson1112 is offline
Old 05-02-2014, 09:39 PM
mongolchuck
mongolchuck's Avatar
I just want to thank you for spelling vacuum correctly.
mongolchuck is offline
Old 05-02-2014, 09:58 PM
MacSerio
MacSerio's Avatar
well i just cleaned that solenoid a second time, and it seems to be working properly once again. it is not sucking air at idle any longer. Yet my idle is still quite erratic....is there a sure tall tale way to diagnose a bad balancer? i see a bit of wobble and minor wear on the rubber ring...
MacSerio is offline
Old 05-02-2014, 10:03 PM
MacSerio
MacSerio's Avatar
i doubt the solenoid is causing the idle issue, as the issue remains with the solenoid unplugged as well....after resetting tps and idle, it wont idle smooth at startup like it did before, but it does seem to be running better and idle a bit better after throttle...and ive fixed all vacuum lines, i dont see that being the problem now either.
MacSerio is offline
mtgldr
02-03-2024 09:00 PM
Pyrate Dave
09-10-2015 07:30 PM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
zanemoseley
09-06-2015 12:58 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: 91 GT Strange idle issue after throttle pressed???
