car will rev past 4,000rpm but wont drive past 4,000 rpm
I am saying it was a vacuum leak. I spent all weekend taking the engine completely apart. The lower intake someone didn't even bolt it on... I took the bolts out by hand! The lower gasket was barely even on the intake. All the intake gaskets were in pretty rough shape including the head gaskets. 1 of the head gaskets was leaking fluid into the pistons. I still have the car tore apart but hoping this was the issue. I am certain it is because it was in pretty rough shape. Whoever put the car together last was either very drunk or didn't know what he was doing.
I know doing it yourself is the best way to do it! So now I just need to get my ECM lined out for the E303 cam going into the car. Does anyone know of a thread or have a link to a place talking about converting a 1994 computer to a 1993?
Doesn't the 302 use 1.6" rocker arms? 1.7 seems way too big
TFS-51400510 - 1.6 3/8" Stud Mount Rocker Arms
that's the part from the Trick Flow top end kit, and searching on Summit shows the same 1.6" rocker ratio, so if you're running 1.72", that could cause some issues with higher RPM's as well
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
