95 to 87 mustang transmission swap
Old 08-25-2014, 06:12 PM
95gtconvert
95gtconvert's Avatar
Default 95 to 87 mustang transmission swap
I'm in need of a transmission asap and have an 87 transmission that I need to swap in but can't without a different shift linkage from a foxbody but when my dad and I checked we couldn't figure out how its supposed to reach far enough to my shifter and if I need a different shift lever
both are aod trans but the one in the car has a little electric box on the side whereas the 87 doesn't
95gtconvert is offline
Old 08-25-2014, 08:09 PM
dawson1112
dawson1112's Avatar
Im not sure youll be able to use that trans, at least not in the conventional sn95 way. The 87 trans is a AOD( automatic overdrive ), while the 95 is an AODE ( E meaning electronic automatic overdrive )
The AODE shift points are controlled via the PCM , ane the AOD is controlled via tv cable, ( commonly known as a kick down cable ) .
Now here is the good news for you.
To make this work and work correctly, you need to swap the upper intake over to a foxbody intake, or swap out the upper and lower intake to GT40 explorer type intake.
You also need a foxbody throttle body, a foxbody throttle cable, and a TV K/D cable for the AOD. Other wise the trans wont last 6 months. The TV cable must be used and be set correctly or you risk burning the clutch disks up. Not to mention it will shift like poop.
I believe the other rout would be to convert the AOD to a manual valve body where you would be determining shift points and shifting every gear manually.
As far as the shifter is concerned, I believe you can use the sn95 shifter, but the sn95 shifters were set further back than the foxes so you may have to do some fab work to the tunnel to move it forward far enough for the linkage to reach.
The computer will probly spit some codes out when it doesn't detect any transmission feedback, But Im pretty sure it will be ok to use, I could be wrong on this and you may need to switch to a manual trans computer.
There are probly other ways around all this, but in the end you will be needing to do some fab work. There is no direct bolt on way to go. That I know of.
dawson1112 is offline
Old 08-25-2014, 08:16 PM
dawson1112
dawson1112's Avatar
You may need to go to a foxbody style shifter, I believe the 95 had a push button for over drive and the fox had an extra position for od.
Old 08-25-2014, 08:50 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it's as simple as this.....no need to do any otheR BS....find a aode, aod won't work/is not a direct swap.........or have your aode rebuilt.
mjr46 is offline
Old 08-25-2014, 09:23 PM
95gtconvert
I'm screwed because I have no parts or money available...oh well looks like it's going to be my motor swap sooner than I wanted but it's needed at this point I have a carbed 87 motor as well for my car will this work for my aod or is there something else I'm missing
I really don't want to have to go crazy with my spending I feel like my dad uncle and I will be like these guys trying to get this done in the next couple of weeks before school starts
Old 08-26-2014, 07:26 AM
88 orangepeel notch
88 orangepeel notch's Avatar
The AOD will work behind that motor, but as dawson said, make sure the TV cable is adjusted properly.
88 orangepeel notch is offline
Old 08-27-2014, 10:06 AM
95gtconvert
Can I just swap to the TV cable or do I need to get all the other stuff to
Old 08-27-2014, 10:43 AM
dawson1112
dawson1112's Avatar
TV cable wont be long enough to reach the throttle body using a sn95 intake because of the elbow they added to it.
As well as there is no place to connect it to the 95 throttle body.
There is a lot that needs done for it to work.
Old 08-27-2014, 10:41 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
sounds like its time for a 4r70w swap
rmodel65 is offline
Old 08-28-2014, 10:02 PM
95gtconvert
4r70w?
Is it auto or manual
Quick Reply: 95 to 87 mustang transmission swap
